Author: Subject: Very stiff clutch
Nitrogeno25
posted on 31/8/12 at 05:40 PM Reply With Quote
Very stiff clutch
I've just bleed my cluth for the first time. The engine is a 2.0 Duratec with raceline flywheel and AP pressure plate.
I have a 6.5:1 pedal ratio and a 0.75" master cylinder. I noticed the clutch is on the hard side comparing with my old cable setup (another engine as well).
Also the clutch seems to disengage with very little movement on the pedal.
Does anybody have any experience with this setup? should I change to a 0.625" master cylinder?
Thank you very much!!
