matty h
| posted on 27/10/12 at 06:26 PM |
Would you fit a bigger engine
I have a 1.4 k series escort based striker and I am considering if to fit a larger capacity k series engine or not.
Currently the car is low tax and good on fuel but I seem to have the urge for more power to do this with the 1.4 would cost ££££ with not huge gains
where as you can purchase a 1.8 160 vvc engine etc for around £250 - £300.
If I fitted a larger engine I would get more power and torque but pay more road tax and loose a few mpg.
What does everone else think.
Thanks Matty
Nickp
| posted on 27/10/12 at 06:32 PM |
You could fit the 1.8 and pretend it never happened, but that would clearly be irresponsible
perksy
| posted on 27/10/12 at 06:43 PM |
Don't think i'd ever worry about MPG in a 7
Unless you were using it everyday to travel a fair distance to work
As ever try and budget it out, but the bigger engine has to be worth a look...
| posted on 27/10/12 at 06:58 PM |
Yep, 6.0L Ls Chevy..
daniel mason
| posted on 27/10/12 at 07:07 PM |
id go for the 1.6 and send it to dva. the 1.6 is much more of a screamer than the 1.8!
adithorp
| posted on 27/10/12 at 07:09 PM |
...or fit a smaller engine, get low tax and more power
Seriously though, fit the bigger engine. If you really are more interested in economy and taxation than performance sell the 7 and by a Matiz.
http://jpsc.org.uk/forum/
tomgregory2000
| posted on 27/10/12 at 07:11 PM |
What about slapping a small turbo onto your current engine?????????
Nickp
| posted on 27/10/12 at 07:23 PM |
Now there's a thought. Probably higher MPG and insurance but tax would remain the same I guess? But it does sound more interesting then slapping
a 1.8 in and Rover kindly provided a turbo setup for just such a thing
swanny
| posted on 27/10/12 at 08:46 PM |
how much mpg would you actually lose? might you not benefit from the later design of the k series?
i have a 1.8 k in my gtm and get about 35 to the gallon on short spirited trips and 45 on motorways. i guess the gtm is heavier than your seven but
more aerodynamic?
| posted on 27/10/12 at 09:01 PM |
Even a normal 1.6 from a 45 is a better choice it has a lot more extra low and mid-range ummph than the extra 10hp would suggest, I am assuming
you already have the normal 103ps 1.4 rather than the low insurance 81ps version used in the base model Rover 25.
The 1.8 isn't near as free revving as the smaller versions and VVC is an extra layer of complication. Advertised MG-Rover engine powers
are based on marketing niches not real output a 1.8 VVC 160 produces closer to 150ps than 160ps.
matty h
| posted on 27/10/12 at 09:04 PM |
Not overly bothered about MPG but just do not want it to cost me a fortune if I go for a trip out probably would not make a big difference on MPG
between the engines.
The turbo engine does sound intresting if not a bit more complex.
I have read that the 1.4 and 1.6 engines do rev more freely due to the stroke but then again a 1.8 would have more torque.
Simon
| posted on 27/10/12 at 09:13 PM |
Get a blower from a bmw mini - get the feel of a bigger engine with none of the negatives. And it should be cheapish!
Simon
davidimurray
| posted on 27/10/12 at 09:17 PM |
How about a few tweaks ........
http://forums.mg-rover.org/showthread.php?t=413045
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
matty h
| posted on 27/10/12 at 09:18 PM |
What is required change a 1.4 mpi engine into a 1.6 would it just be change the pistons and liners and fit a 1.6 ecu and injectors.Is it also worth
fitting either a vvc head and inlet manifold.
Also intrested to know what is involved for a turbo conversion.
Matty
| posted on 27/10/12 at 10:04 PM |
Changing liners is waste of time and money fit a complete 1.6 engine and swap the flywheels, VVC inlet can be fitted to the normal 16 valve head.
Just be sure to find a good engine.
VVC exhaust cams can be used to replace both the inlet and exhaust cams on the normal 16 valve head to give a decent boost in power the catch is VVC
exhaust cams are like unicorn droppings
daniel mason
| posted on 27/10/12 at 10:14 PM |
id keep looking on l7c. k series motors come up for sale regularly on there but good ones are not cheap. you could almost certainly fit a zetec for
less!
i just sold my complete minister tuned 1.4 k with box and all anciilaries for £1600 within a few hours and could have sold it for more.to at least 3
other people.couldnt believe the interest.but it was a cracking motor with around 130 bhp
owelly
| posted on 28/10/12 at 07:59 AM |
I know of a cracking 1.8 K series out of an MGF that's for sale. My chum (Trev Borg) on here had it in his MGF. He then sold it to a work
colleague of mine to put in a Mini. The engine has sat next to the Mini for a couple of weeks and now blokey has decided he wants to keep the Mini
A-series powered!
http://www.ppcmag.co.uk
