laptoprob
| posted on 9/11/12 at 06:30 PM |
Sequential box
Just having a quick thought about winter mods as you do......
I currently have a Tran-x straight cut box in with the Westfield 5" remote extension fitted in my Tiger Avon.
I wondering if sequential boxes are the same length and if not what can be done if anything to lengthen the gear lever??
PumaWestie
| posted on 9/11/12 at 07:51 PM |
The lite IL200 is roughly the same length but requires a different propshaft end and mounting. The gearlever is on a framework gantry which can be
extended or mounted directly to the chassis as the lever uses cables to operate the shift mechanism
laptoprob
| posted on 9/11/12 at 08:37 PM |
Hmmmm sounds too easy
Got any pics etc?
PumaWestie
| posted on 10/11/12 at 08:42 AM |
Google Elite IL200 gearbox under images
