Andybarbet
| posted on 5/2/13 at 09:03 PM |
Any major difference in blacktop engines ?
A friend needs a new head for his transit connect 1.8 blacktop zetec on a 2001 year & has been offered a complete 2004 1.8 engine from a focus.
Are there any major differences between the years - if any ??
Cheers !
Xtreme Kermit
| posted on 5/2/13 at 09:45 PM |
I'm no expert but I thought they were all pretty similar.
Maybe small cam differences?
austin man
| posted on 5/2/13 at 11:17 PM |
I know that the silvertop 1.8 and 2 litre are different, believe it or not we got a better BHP from a 1.8 head on a 2 litre than we did using the 2
litre
Paul Turner
| posted on 6/2/13 at 07:56 AM |
litre
By putting a 1.8 head on a 2 litre you raised the compression ratio, simple as that.
chillis
| posted on 6/2/13 at 12:48 PM |
Check the head part number on the side of the head above the exhaust manifold. There may be differences between pass car and commercial
applications.
Not usually a good idea to swap between Silvertop and Blacktop as they have lots of differences.
Never under estimate the ingenuity of an idiot!
Paul Turner
| posted on 6/2/13 at 01:01 PM |
As supplied by the factory there is absolutely no way the Silvertop and Blacktop heads are interchangeable. The cambelt tensioning pulleys are in
different places for starters.
Swapping a complete engine is not a major issue, 1 modified engine mount, modifed alternator mount, idler pulley for alternator belt, Scholar kit to
fit Silvertop windage tray/sump and a couple of coolant hoses were all I had to sort on mine when I swapped form Silvertop to Blacktop.
