Dooey99
| posted on 9/2/13 at 09:27 PM |
Zetec Big Valves
Does any body know where i can buy big valves for my 1.8L blacktop Zetec engine
Less weight more speed, more power more speed
If in doubt, give it a clout
Charlie_Zetec
| posted on 9/2/13 at 10:28 PM |
Tried Burton Power? If not in their catalogue, might be worth a call...
snapper
| posted on 10/2/13 at 09:18 AM |
GS valves
REC
I eat to survive
I drink to forget
Paul Turner
| posted on 10/2/13 at 09:21 AM |
Dooey99
Why, when you said in a recent post Thanks mate will give you a shout if I need any help, I have access to a rolling road and I can map ECUs and
stuff as I work for a lotus race team and we are currently having bespoke throttle bodies built, I build performance engines weekly but I have never
used bike carbs before do you have to keep asking these basis questions.
Surely if you are really "building performance engines weekly" you would know the answer to this and the recent questions regarding
fitting cams and lightening flywheels. If not another professional at the "lotus race team" would be able to help you without resorting to
us amateurs on the internet.
To prove I am not making this up here is a link http://www.locostbuilders.co.uk/viewthread.php?tid=178214&page=0&contribmessage=none 7th post
down.
BaileyPerformance
| posted on 11/2/13 at 05:36 PM |
quote: Originally posted by Paul Turner
Dooey99
down.
More to the point why would anyone tune a 1.8L zetec when there is a 2.0L available? ;-)
Never found the need to use bigger valves in a zetec, but we normally build forced induction engines so maybe its not so important, would be
interesting to do a back to back on the dyno - stock valves verses 1mm oversize?
snakebelly
| posted on 11/2/13 at 05:46 PM |
we ended up with 1mm oversize on our scholar race zetec, but only becuase a spark plug failure damaged one of the seats so bad it was either go up 1mm
and recut or fit an insert, wasnt going to happen!
We saw about another 15bhp but the head was heavily modified and we ran custom cams so no real comparison to a standard engine.
Scholar can supply oversize valves but as has already been said, why would you bother?
