laptoprob
| posted on 14/3/13 at 08:00 AM |
Boosting through Weber TB's?
I currently run some of these on my XE install but they are as old as the ark.(10 yrs+)
My question is has anyone run boost through these?
I know Jenvey change the butterflys for stronger versions to stop them bending when the throttle is shut.
Other worry is if they leak anywhere under boost.
Bit of a long shot i know but any advice would be a bonus
Norfolkluegojnr
| posted on 14/3/13 at 08:56 AM |
Didn't the Lotus Esprit use a turbo and a DCOE style carb? not sure it'll help but might be a good starting point.
I can only talk about SU's, but the carb on my A series is different to a standard HIF44 - seals are uprated and certain lean off breathers etc
are blanked off.
Norfolkluegojnr
| posted on 14/3/13 at 09:00 AM |
Found it:
You can run an un-sealed carb on a blow through setup though. Lotus did it running a pair of 40's (dell'ortos). The carbs sit in a
sealed plenum chamber and the pressure from the turbo is applied to that - inside and outside of the carb see the same pressure so no issues with the
carb blowing a fuel and air mixture out of the spindles and whatnot.
Not my wise words, but I new i'd read it some where. i gues sspace may be an issue on a kit, but might be worth looking into.
[Edited on 14/3/13 by Norfolkluegojnr]
BaileyPerformance
| posted on 14/3/13 at 09:30 AM |
Weber throttle bodies - these where made by Jenvey for weber. You can boost these no problem, if the seals/shafts are worn you will loose some boost
but nothing to effect performance.
What engine management have you got? mapping TBs with a turbo/SC can be hard, you need an ECU that will use the TPS and MAP. TPS for off-boost and MAP
for extra fuel on boost.
Let me know if you need further advise as we have done this before on Cosworth YB, zetecs and redtops.
Cheers Dale www.baileyperformance.co.uk
| posted on 14/3/13 at 10:16 AM |
quote: Originally posted by Norfolkluegojnr
Found it:
The Dellortos used by Lotus on the turbo Esprit were not standard DHLA's, they were developed by Dellorto specifically for the Lotus and have an
extra jet circuit to provide enrichment as the boost rises.
However, I have seen standard DCOE/DHLA carbs successfully in a blow through system, though I don't know all the modifications required (apart
from sealed spindle bearings and suitable jetting). You could probably do what AR did for the SU in the Metro Turbo and use a restrictor on the carb
inlet to make it pressure sensitive.
[Edited on 14/3/13 by MikeRJ]
snapper
| posted on 14/3/13 at 07:04 PM |
Webers need to be in a sealed box
The way carbs work means the internal air flow caused by the Venturi causes vacuum that pulls fuel in
If you pressurise the port flow you will blow fuel out of the various holes
Another issue is the carbs don't see pressure just airflow through the Venturi
You can suck through a weber or an SU like a Montego turbo does
Anything fuel injected is a much easier modification
I eat to survive
I drink to forget
laptoprob
| posted on 15/3/13 at 08:00 AM |
Saved me again Dan.....
I have an new Emerald ecu so mapping wont be an issue really.
Thanks for the info on my throttle bodies though, think i will give it a go and i reckon if its setup right it will give better response etc.
[Edited on 15/3/13 by laptoprob]
40inches
| posted on 15/3/13 at 08:46 AM |
Seems to be some confusion here. The way I read the OP's first post, he is using Weber Throttle Bodies not carbs.
Slimy38
| posted on 15/3/13 at 09:27 AM |
I was going to say the same thing, boosting through fuel injected throttle bodies shouldn't pose much of a problem compared to the headache of
working with carbs.
laptoprob
| posted on 15/3/13 at 10:11 AM |
working with carbs.
Hehe
I saw that too but thought i`d let them prove points on carbs between themselves.
Dan@Bailey has pointed where i need to now anyway
Thanks again!
40inches
| posted on 15/3/13 at 02:25 PM |
working with carbs.
Hehe
Thanks again!
Has anyone ever told you that you are evil
laptoprob
| posted on 15/3/13 at 02:50 PM |
working with carbs.
Hehe
Thanks again!
My wife....daily
| posted on 15/3/13 at 05:47 PM |
Not that it's relevant to the thread but the Montego uses an SU in a blow through system, same as the Metro Turbo.
