Dick Axtell
| posted on 11/4/13 at 04:15 PM |
Polo Rad Fan Switch Seal Q
Have searched back-posts for this. Only found 1 - which was another question!!
So - What did all you other Polo rad installers use to seal the fan switch? There is a plastic blanking plug, which could provide a rubber seal.
Otherwise, I thought of using PTFE tape, as per household plumbing.
Which do existing users recommend?
loggyboy
| posted on 11/4/13 at 04:17 PM |
Surely just doing it up tightly is enough for the plastic to seal it sufficently. Cant think the manfacturers would be applying any extra seal.
Mistral Motorsport
theprisioner
| posted on 11/4/13 at 04:21 PM |
My rad switch, that I do not use, came with a sealing ring, metal of some sort, looks like alloy. I guess you could turn one on a lathe if you lost
it.
renetom
| posted on 11/4/13 at 04:48 PM |
Definately ptfe tape, that what we used on ours
works fine.
Dick Axtell
| posted on 11/4/13 at 06:45 PM |
Thanls all, for the suggestions and advice.
