rewbank
posted on 3/10/04 at 12:48 PM |
Component Masses please?
I'm trying to redesign the locost chassis but to start with i need to know the masses of the components. If anybody is aware of the masses for a
1600 ford kent engine, a ford escort mk 1 gear box,prop shaft, rear diff and axel I would be extremely grateful. This is so I can determine the
bending forces on the chassis. Thank you!
Bob C
| posted on 4/10/04 at 11:21 AM |
Not much help but the only thing I've seen with a list of weights was onRichard Miles srtikerr1 site
http://www.striker1.plus.com/
cheers
Bob
PS remember you will be the heaviest or 2nd heaviest thing in the car - mine's a BEC so I'm the heaviest....
Bob C
cheers
Bob
rewbank
| posted on 4/10/04 at 02:23 PM |
Cheers Bob,
I'll have a good look at the web site you have suggested. I really appreciate the help.
Richard
stressy
| posted on 4/10/04 at 07:05 PM |
some rough numbers only im afraid
I weighed a 1600 gt crossflow, it was dry with no alternator but did have carbs,dizzy and flywheel it was about 115-120kg.
the escort axle i had was fitted with the larger drums and had been braked for a locost and was about 47kg i think.
The type 9 5 speed gearbox i have is around 29kg dry and i know from conversation with a freind he found the 4 speed to be nearly 20lbs lighter when
he did a swap so i guess a fourspeed must be aroundabout 20-22kg or thereabouts.
i know my probshaft is just under 4kg but it is vey short and is a bailey and morris low torque type (lighter) so i guess it will be a little more
than that.
hope this is of some use it should at least get you in the ballpark,
WHO DARES SPINS
stressy
| posted on 4/10/04 at 07:10 PM |
hi again, i just checked me note book and the gearbox was 31kg not 29 so the 4 speed could be a little more than 22kg. As i say ballpark numbers
WHO DARES SPINS
rewbank
| posted on 5/10/04 at 09:55 AM |
Cheers stressy,
You don't know how hard it is trying to find these figures. I really appreciate the help,
Rich.
