Avoneer
| posted on 3/10/04 at 03:12 PM |
1st Gear "Judder"
Anyone else experienced some "judder" when setting off in 1st gear. Only noticed it a few times when the car has been running a while and
especially at Elvington yesterday when the car was "on fire". Northy mentioned it was because the clutch was hot.
Any ideas anyone?
Pat...
| posted on 3/10/04 at 03:43 PM |
Could be oil on clutch , this would cause clutch judder, if the problem persist's try pulling off in 2nd or maybe 3rd gear . This will cause the
clutch to slip, get hot and hopefully burn off any oil . If this cures fault for a while you could have a rear main or possibly gearboxfront oil seal
leaking. Hope this helps . Rusty
| posted on 3/10/04 at 04:36 PM |
Clutch warping when hot
It'll wear itself flat again.
Avoneer
| posted on 3/10/04 at 05:09 PM |
Cheers.
Will give that a go. Did have a leak from the bell housing at one point...
Pat....
Mark Allanson
| posted on 3/10/04 at 06:31 PM |
Sounds spot on , Pete
My road car does this after a long hard run, back to normal when driving locally
