novicebuilder
| posted on 11/5/13 at 09:58 PM |
Which brakes shall I use?
I have brakes and hubs from two separate donor cars and I need some guidance about which would be best in my Haynes roadster. One donor car has disc
brake front and back and ABS, the other has discs front and drums rear, no ABS, normal master cylinder with servo. I want to use the master cylinder
from the second car but can I use the all round disc brakes from the first car or should I stick with its original set up of disc and drum? Thanks.
[Edited on 11/5/13 by novicebuilder]
imp paul
| posted on 11/5/13 at 10:01 PM |
kebab
mookaloid
| posted on 11/5/13 at 10:04 PM |
4
jollygreengiant
| posted on 11/5/13 at 10:05 PM |
G -
String
Clamp
G
Haaaaaa
Wizz
Ronnieeeeeemo
imp paul
| posted on 11/5/13 at 10:07 PM |
quote: Originally posted by mookaloid
4
o yes im with mooky on this
pewe
| posted on 11/5/13 at 10:11 PM |
-spot?
mookaloid
| posted on 11/5/13 at 10:12 PM |
quote: Originally posted by pewe
-spot?
oooh cheeky
imp paul
| posted on 11/5/13 at 10:14 PM |
-spot?
its the bum duffer
imp paul
| posted on 11/5/13 at 10:19 PM |
re brakes most of the builders use disks all round you don't have to use the abs
novicebuilder
| posted on 11/5/13 at 10:35 PM |
Will the master cylinder from the disc/drum car work with just as well with discs front and back?
mookaloid
| posted on 11/5/13 at 11:26 PM |
you might well need to install a balance valve so you can adjust the balance front to rear or the rear might be overbraked -( which is not a good
thing )
jps
| posted on 12/5/13 at 07:44 AM |
thing )
you'll need to use the inertia valve that is fitted to the sierra to stop the rears overtaking and locking up. it's detailed in the
book.
