Author: Subject: Duratec Clutch
ChrisJ15
posted on 13/5/13 at 08:49 AM Reply With Quote
Duratec Clutch
Ive got a standard gearbox from an ST150 in my kit which doesnt retain the standard pedal box and master cylinder.
My question is, do I need to restrict the movement of the pedal so that I don't throw the release bearing out too far and do damage?
flak monkey
posted on 13/5/13 at 07:33 PM Reply With Quote
Yes, you need to find out the bore size of the slave and master cylinders and work out the relevant travel required...
ChrisJ15
posted on 14/5/13 at 08:07 AM Reply With Quote
Sounds pretty technical to me!
Cant I just put a stop on the clutch pedal and adjust it so the there is very little movement after the clutch has disengaged?
flak monkey
posted on 15/5/13 at 05:06 PM Reply With Quote
Yep, if you can see it. But normally you can't....
