Author: Subject: 1.8 cvh wiring
scottc1088
posted on 18/5/13 at 03:25 PM Reply With Quote
1.8 cvh wiring
does anyone have a wiring diagram for this engine? iv just fitted one in my reliant kitten and need to wire it up
thanks
AdrianH
posted on 18/5/13 at 06:08 PM Reply With Quote
Is the engine CFi or carb'd, I could probably scan and send you the pages from the Sierra book.
Adrian
Why do I have to make the tools to finish the job? More time then money.
scottc1088
posted on 18/5/13 at 08:22 PM Reply With Quote
its the carb model with the esc hybrid setup
the loom i have has been cut before the connector so i just have a bunch of wires coming from the esc unit that i need to connect
i guess it only needs a few wires to run though
AdrianH
posted on 18/5/13 at 09:15 PM Reply With Quote
I have scanned the three pages I used on my build using the same setup.
If you have the alternator and original carb then easy.
U2U me an email address and I will send over three pdf's
Adrian
scottc1088
posted on 18/5/13 at 09:48 PM Reply With Quote
u2u'd
thanks
AdrianH
posted on 18/5/13 at 10:01 PM Reply With Quote
3 emails to ensure they are not blocked due to size
Welcome to the Forum
Adrian
scottc1088
posted on 18/5/13 at 10:21 PM Reply With Quote
received, thank you
hopefully the engine will be ready to run this week. once its running ill be looking into fitting a turbo
