Trollyjack
| posted on 13/6/13 at 08:38 AM |
In which order do I install a fuel pump
Hi
In which order do I install my fuel pump and filter
I have a petrol tank and the take of at the bottom of the tank is at 1 end
The guy I got it off said the he kept getting a fuel starvation an long left had corners when fuel was low
My intention is to put in a swirl pot to eliviate this problem.
Its feeding a twin choke weber.
In waht order do I fit the fuel pump (facit type) and filter
To I go
Tank, Swirl pot, Pump, Filter, Regulator, Carb
Or
Tank, Swirl pot, Filter, Pump. Regulator, Carb
TrollyJack
tilly819
| posted on 13/6/13 at 08:45 AM |
No sure about a carb set up with a pot, but regardless of were the pot is the filter should be before the pump as it is there to stop you damaging the
pump as well as stopping crud going into the carbs/injectors
hope this helps
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
big-vee-twin
| posted on 13/6/13 at 08:49 AM |
Agreed, first thing from the tank should be the fliter.
http://www.triangleltd.com
daveb666
| posted on 13/6/13 at 09:23 AM |
Tank
Filter
Lift pump
Swirl pot
Hi pressure pump
dave_424
In an ideal situation there should be a filter before and after the pump, so any debris from the pump doesn't make it to the carbs/regulator.
If it was just one filter then I would put it after the pump, the pump should have a wire mesh screen on the inlet anyways
adithorp
| posted on 13/6/13 at 09:41 AM |
There should be a filter before the pump but only a gauze to catch larger debris. A proper filter will restrict the flow to much and cause cavitation
in the fuel. Fuel pumps don't like to suck and work best with free flow into them.
http://jpsc.org.uk/forum/
Smoking Frog
| posted on 13/6/13 at 09:59 AM |
I don't think you need a swirl pot with carbs, they have a reservoir.
