Dooey99
| posted on 3/12/13 at 07:47 PM |
Main cap bolts NEEDED
I'm after the crankshaft bearing cap bolts out of a 1.8L silvertop zetec engine, or if not just the four that also hold splash tray in the sump
as these are the 4 I need.
Someone please help out a fellow car builder I'm willing to pay for the bolts and postage and beer. I just can't source these bolts any
where and I've been searching for about a month, the only ones I can find are ARP but I can't warrant spending £100 for 4 blasted bolts
Thank you in advance
Less weight more speed, more power more speed
If in doubt, give it a clout
umgrybab
| posted on 3/12/13 at 10:39 PM |
What are the specs and I can see what our works fastener supplier can do them for.
Dooey99
| posted on 3/12/13 at 10:44 PM |
Tbh I haven't a clue, I need to it them in the newer zetec engine to allow me to put my Era sump in :/ I think, like the cap of the bolt has a
thread cut internally in it to allow another smaller bolt to go in
Paul Turner
| posted on 4/12/13 at 07:36 AM |
Told you before. Contact Scholar engines, they will sell you 4 Silvertop maincap bolts and spacers to suit a Blacktop that will allow you to fit the
windage tray.
http://www.scholarengines.co.uk/contact.html
Used them on my Blacktop, cost £16 posted.
Dooey99
| posted on 4/12/13 at 09:50 AM |
Thanks mate
I never saw it before perhaps I'm just thick LOL
Dooey99
| posted on 4/12/13 at 11:07 AM |
£58.92 from scholar engines f*ck me that's not cheap either
Paul Turner
| posted on 4/12/13 at 11:13 AM |
That price is probably for the whole conversion kit to fit the Silvertop sump onto a Blacktop which includes the windage tray.
Dunnell (who charge stupid prices) charge £70 for kit which includes the bolts, spacers and windage tray.
If you only need the bolts and spacers it much cheaper, as I said I paid them £16 inc P & P.
[Edited on 4/12/13 by Paul Turner]
DW100
| posted on 4/12/13 at 11:47 AM |
Sorry am I missing something here?
They are standard parts.
Is the obvious thing not you local ford agent? Go in look at the pretty pictures on the screen and say "i'll have some of those
please"
Paul Turner
| posted on 4/12/13 at 12:01 PM |
please"
The bolts are standard Ford parts but you need the spacers to fit under them. Unless the spacers are made of a suitable material and correctly
machined there is a very good chance the bolts could loosen under normal use and then the loose cap would probably cause terminal engine failure.
For the sake of a few quid is it worth risking engine failure.
As I said I am 100% certain Scholar have quoted for a kit including the windage tray. If Dooey99 does not have a windage tray and needs one this that
is a decent price, if he doesn't need it they will simply sell him bolts and spacers.
Dooey99
| posted on 17/12/13 at 07:13 PM |
I have finally go the bolts I needed! Can Anyone tell me the size of tHe spacers I need between the cap and the bolt head? So the crank doesn't
hit the windage tray or do you put the spacers between the windage tray and the bolt on the smaller thread?
big_wasa
| posted on 17/12/13 at 07:25 PM |
I am sure its 20mm BUT CHECK FOR YOUR SELF.
Dooey99
| posted on 17/12/13 at 07:30 PM |
I read somewhere else it was 20mm and I'm about to measure bolts and have a look but do I need to have a smaller diameter bit on the of the
spacer to sit in the cap?
big_wasa
| posted on 17/12/13 at 07:32 PM |
I am sure a set I had made up where 20mm x 20mm and just sat on the bearing caps with out binding or catching.
Dooey99
| posted on 17/12/13 at 08:06 PM |
Did you try using silvertop main bearing caps on the blacktop using the blacktop bearings? Or is that a big no go
| posted on 17/12/13 at 08:10 PM |
Definitely a no go, unless you get the assembled block line bored afterwards.
Dooey99
| posted on 17/12/13 at 08:12 PM |
I'll give that a miss then I have found the spacers I think I need for £12 posted so ill order them
