pekwah1
| posted on 29/1/14 at 09:11 PM |
2.0 Blacktop zetec flywheel
Hi Guys,
I'm fitting a 2.0 blacktop to my type 9.
Can i use the standard flywheel, clutch and cover?
I know i'd need a spigot bearing a ct133, but someone mentioned something about needing to modify the clutch arm....
Is this just a load of rubbish?
stevebubs
| posted on 29/1/14 at 09:23 PM |
No issues for me, but I swapped the flywheel for a 1.8 as it's lighter..
Dusty
| posted on 29/1/14 at 09:47 PM |
You will need a spigot bearing. Ebay or your local ford dealer.
CCT133 is the QH part number for the correct clutch arm release bearing if mating to a type nine without modification to the clutch arm pivot point.
| posted on 30/1/14 at 12:47 AM |
All you need is a solid flywheel off a 1.8 escort, spigot bearing, the clutch off a mk1 mondeo and a ct133 release bearing. The type 9 release arm
will be ok.
