Author: Subject: DIY injector cleaning?
johnH20
posted on 7/7/14 at 05:31 PM Reply With Quote
As above, is it possible, if so how. My engine has been inactive for several years and I am attempting first start. Seem to have a good set of plugs and the engine will spin over , cough and fire for a few revs but not run. I suspect injectors but it could of course be something else. Any tips welcomed.
43655
posted on 7/7/14 at 05:39 PM Reply With Quote
ultrasonic cleaning is good for injectors. shouldn't cost much to have them done. hell an ultrasonic jewelry cleaner would do the job
stevebubs
posted on 7/7/14 at 07:26 PM Reply With Quote
http://www.rowand.net/Shop/Tech/DIYFuelInjectorCleaning.htm
Worth a shot?
stevebubs
posted on 7/7/14 at 07:27 PM Reply With Quote
Do you have a fuel pressure? What ECU are you running? Can you see a spark?
[Edited on 7/7/14 by stevebubs]
mark chandler
posted on 7/7/14 at 09:55 PM Reply With Quote
I cleaned mine, old fuel pump, mains 12v battery charger with only 1 diode, thinners & a couple of big jars.
The charger pulses 12v @ 50hz and runs the pump and injector, join these together with a bit of rubber tube drop the pump into a half full jar of thinners, injector points back into the jar and plug it in.
After about 15 minutes my worst injector was spraying a nice clean jet, I then squirted the injector into a measuring jug and timed how long it took to fill, did each in turn until they all passed similar quantities of fuel.
johnH20
posted on 8/7/14 at 08:19 AM Reply With Quote
Mark, what thinners did you use? Link above talks about carb cleaner but does that exist anymore? Going to give your method a try.
mark chandler
posted on 8/7/14 at 12:03 PM Reply With Quote
Cheap cellulose gun cleaner did it for me, you can still get it from good motor factors or even diesel on petrol injectors.
Make sure you terminate the leads well, sparks are bad news!
johnH20
posted on 8/7/14 at 12:39 PM Reply With Quote
Thanks Mark.
garyo
posted on 8/7/14 at 02:26 PM Reply With Quote
Try spraying a mist of carb cleaner or petrol down the throttle bodies to see if it momentarily springs in to life - they at least you'll have sanity checked that it's definitely a fuelling issue
