Trev Borg
| posted on 17/11/04 at 08:21 PM |
clutch release bearings
The story so far.
Mating alfa V6 to type 9 with homemade belhousing.
The type 9 has a square ended clutch release bearing hub thingy, and the springs on the alfa pressure plate are also straight.
I have been told that if the springs are straight , then a round ended bearing hub is needed, and if the springs are curved, a flat edged hub is
needed.
Is this correct ?
If so, can you get a round edged release bearing hub to fit a type 9
Next task. I think the type 9 I have is from a rear wheel drive 2.8 Sierra. Is this different in any way to your run of the mill 2.0 sierra type 9.
I remember reading about diffrent shaft lengths ?
Are any stronger, weaker, better than others ?
All and any comments welcome
stevebubs
| posted on 17/11/04 at 08:32 PM |
If it's from a 2.8 Sierra, then the input shaft is a little bit longer, the gearset is a little stronger and 1st gear is better suited for our
cars (slightly longer (?) ratio so 1st actually becomes useful and you're not straight into second)....
Trev Borg
| posted on 2/12/04 at 09:40 PM |
Come on someone must know.
If my clutch springs are flat, do i need a round ended clutch release bearing or will the flat ended one i already have do.
Do it make ant difference ?
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
| posted on 2/12/04 at 10:20 PM |
I don't remember which it was but my nephew has a 1.8cvh Sierra which had the wrong thrust bearing fitted and it ate through the diaphragm
spring and left him stranded without gears.
907
| posted on 2/12/04 at 11:04 PM |
Hi Trev,
I think your right Trev, a flat needs a curve and vice versa.
I fitted a concentric unit from a Mundano (flat bearing) to my 907 (flat clutch fingers).
I got over the problem by fitting a bronze insert into the face of the thrust bearing,
nicely curved on my mates mill. (see pic)
Paul G
Trev Borg
| posted on 3/12/04 at 08:46 PM |
Very pretty indeed.
Is there any 23 splined ones that have a rounded face, or are they all flat ?
[Edited on 3/12/2004 by Trev Borg]
907
| posted on 4/12/04 at 07:31 AM |
Don't know the answer to that one, sorry.
Good luck with the Alfa though, I like Alfa's.
Paul G
