| posted on 7/11/14 at 04:38 PM |
Type E / Rocket Box and Type 9
Does anyone know if the Type E / Rocket / RS2000 gearboxes has the same bellhousing pattern as the Type 9?
My gut feeling is 'no', but thought I'd better ask.
It's Evolution Baby!
ali f27
| posted on 7/11/14 at 04:49 PM |
yes
mcerd1
| posted on 7/11/14 at 04:52 PM |
I've got a spare type 9 I can lend you if you need it to check (I'll need it back as it may need to go in my dax someday....)
| posted on 7/11/14 at 05:10 PM |
Thanks for the offer Robert... I've a Type 9 (with bell housing) sat in my garage. I also had a Rocket Box casing up until a few weeks ago and
it never occurred to me to check the two side by side!
| posted on 7/11/14 at 05:11 PM |
quote: Originally posted by ali f27
yes
Cheers.
ali f27
| posted on 7/11/14 at 05:36 PM |
I have a couple of bellhousings in the workshop if you need one
Paul Turner
| posted on 8/11/14 at 12:26 PM |
I had a type E in mine and swapped to a type 9. The only changes I had to make were a new gearbox x-member (further back and lower on the type 9) and
a different gear lever. All the other parts were a direct swap. Propshaft was OK in mine but the type 9 is 6mm longer so beware if your prop is an
exact fit.
| posted on 8/11/14 at 12:36 PM |
