wheelsinsteadofhooves
| posted on 30/11/04 at 11:04 PM |
zetec power
hi guys and gals,
ive got a zetec on the go which i'm going to be running on twin 40's, with a megajolt for sparks. fairly standard otherwise. anyone have a
clue as to what the power might be?
i need to get a box for it sooner or later so before i start hunting im after a bit of direction.
will keep one and all posted on megajolt development, hope to do some good things with it.
zetec
| posted on 30/11/04 at 11:36 PM |
1.8 should give 150-155bhp, 2.0 160-165bhp.
You can use a Type 9 or MT75. Type 9 from earlier Sierra up to about 1989ish. Most go for a type 9 if you need to change ratios. I run a standard MT75
which goes just fine.
stevebubs
| posted on 1/12/04 at 02:01 AM |
Cool...I'm going to be running an Emerald myself (albeit on DIY Bike throttle bodies)
Silver top or Black top? Most of the tuning goodies (Raceline et al) are originally designed for a silvertop. I have a blacktop.
Have got a std Type 9 and can confirm that it bolts straight up to the block - but not to the sump although that shouldn't be an issue.
Another useful titbit is get hold of the spacer plate from an 1800 Sierra - will directly replace the Zetec fwd one. Just need to make up a blanking
plate where the starter goes on the Zetec block
Don't forget to get a spigot bearing, and if you're running a 2.0 then you'll need to change the flywheel to either an expensive
bespoke one (e.g. Raceline), a std 1.8 zetec flywheel or a Dunnell lightened 1.8. flywheel Most places can also supply a clutch for a reasonable
price.
Oh..and make the sump shallower...most places charge a fortune for a modified sump. You can get a FF drysump, secondhand DS pump and oil tank for
about the same money if you're willing to hunt. I'm being a cheapskate and intending to make a shallow sump myself (similar to the one on
www.toyne.org)
HTH
Stephen
| posted on 1/12/04 at 09:34 AM |
cheers chaps,
this engine has a bit if a special history and hence is going into something out of the ordinary.
im running a1300 crossflow in my road/race locost, whilst getting this beast ready for the next project. its going to be mid engined, so am looking at
some of the renault/porsche/hewland cogboxes out there.
thanks for power figures, looks like itll be something to mess with!
