Mark100
| posted on 28/8/15 at 06:22 PM |
a giggle for the hive mind
a word of warning to remember when putting your engine and box together
spent two hours wrestling with the flywheel clutch box
then saw this
can you spot the not so deliberate mistake
lol fixed now but still kicking myself
r1_pete
| posted on 28/8/15 at 06:46 PM |
Crank sensor is going to be a loose fit......
Daf
| posted on 28/8/15 at 07:19 PM |
I did this, only I fitted and plumbed the engine in before I realised that I'd made that mistake!
I think I spent longer looking at it in disbelief than it did to pull the engine and fit one!
Mark100
posted on 28/8/15 at 07:53 PM |
yep that's right boys crank sensor mount that bolts in under the flywheel
so glad im not the only one
obfripper
| posted on 28/8/15 at 09:07 PM |
Slightly OT, but where did you get your crank breather plate?
Dave
ALLAN 14
| posted on 29/8/15 at 09:57 AM |
Crank sensor housing Manual Gearbox.
Again only a little a little OT
Do you have a spare housing for manual gearbox C/S?
Nobody is perfect at least it is still on the bench.
Regards
ALLAN
Mark100
| posted on 29/8/15 at 10:24 AM |
ebay then drilled and tapped myself think it was £20 and ill have a look for a spare when I get home might have one
