rich201283
| posted on 11/12/04 at 04:13 PM |
Pinto timing mark?
On a pinto's crank there are 4 timeing marks, which one do you line to crank up with?
macspeedy
| posted on 11/12/04 at 04:23 PM |
the first mark going clockwise is 0 degrees advance unless i am mistaken
jollygreengiant
| posted on 12/12/04 at 11:00 AM |
Should be the bigest/deepest/longest. You will also find timing marks on the cam pulley/head AND a mark on the outer mounting face of the distributor
where the cap fits onto and the rotor arm centre line should be pointing at this for static timing when crank shaft and cam shaft are lined up. A very
desireable pointer when changing cam belts.
Enjoy
| posted on 12/12/04 at 11:41 AM |
On my crank pulley going clockwise the first mark is 16* going down in 4* increments to TDC. There is a faint line in between them, presumably to show
2* intervals. Which engine are you using as the timing is different for different years and capacities. 8* BTDC is a reasonable figure as a starter
for engines running unleaded. If you are just building it or replacing the timing belt line everything up with the TDC marks and set the timing after
with your timing light.
[Edited on 12/12/04 by Peteff]
