tims31
| posted on 27/11/15 at 08:12 PM |
Zetec Blacktop HO2S Plug Wiring
Today I de-pinned all the engine loom plugs for my Blacktop Zetec so I could route them through a grommet into the engine bay, plus I shortened a load
of them now I know how long they need to be. The trouble is now I have checked all the wiring and that’s ok but I have a conflicting diagrams in
regards to how the HO2S plug is wired pin to pin.
What I have is one that shows:
Pin 1: Green/Blue (Pin22 from C2513 plug to switched live)
Pin 2: Black/yellow (Pin 93 on ECU
Pin 3: Brown (Common Earth)
Pin 4: White (Pin 60 on ECU)
And the other one has
Pin 1: Black/yellow
Pin 2: Green/Yellow
Pin 3: White
Pin 4: Brown
I know where the wires go to and what they do, I just need to get the correct wires into the correct pin location for the sensor which is wired:
Pin 1: White
Pin 2: White
Pin 3: Grey
Pin 4: Black
Could anyone please have a look at what they are running and let me know the correct way to wire the plug again
[Edited on 27/11/15 by tims31]
Build: http://www.martinsfurybuild.co.uk/
big_wasa
| posted on 27/11/15 at 09:33 PM |
I will double check in the morning for you, remind me if I foget.
The two white wires are the heater and can be wired either way around.
tims31
| posted on 27/11/15 at 10:01 PM |
Cheers Warren, you're a star
tims31
| posted on 28/11/15 at 03:04 PM |
Hey Warren,
Just a reminder for you mate, any luck finding the wiring for the HO2S plug please?
| posted on 28/11/15 at 04:15 PM |
Hey Warren,
Standard NTK/NGK Zirconnia sensors and some Bosch
Black = Signal
Grey = Sensor Ground
White = Heater + Supply
White = Heater Ground
Whites can be wired either way round
tims31
| posted on 28/11/15 at 05:24 PM |
Black = Signal
Thanks,
Found this online which I think is for a Focus 2.0ltr zetec but pretty sure they will be the same wiring...
big_wasa
| posted on 28/11/15 at 09:25 PM |
Yep looks like your sorted. Sorry for not getting on it but I've not been well.
tims31
| posted on 29/11/15 at 09:48 AM |
No problems Warren, get well soon.
