Author: Subject: Fender / Wing gasket
Dale
posted on 9/1/16 at 07:32 PM Reply With Quote
Hello
I have seen what they call tadpole gasket used between the standard fender and the chassis where there is a 90 deg angle between the parts. What I am looking for is a a rubber seal to be used between the chassis and my rear fenders which are in the same plane as the chassis, as they form a continuous smooth line. I dont know if there is a "T" shaped gasket that would fit tight over the two pieces but i don`t want them to stick up too much as I want it smooth. Also the part transforms from in plane to maybe a 15 deg up angle at the tops of my fenders.
Any Ideas.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
gremlin1234
posted on 9/1/16 at 07:52 PM Reply With Quote
do you mean something like this?
http://www.woolies-trim.co.uk/c-348-wing-piping.aspx
edit:
specifically this
http://www.woolies-trim.co.uk/p-1328-wing-piping.aspx
[Edited on 9/1/16 by gremlin1234]
Dale
posted on 9/1/16 at 08:00 PM Reply With Quote
The last one might be good, Now if I can find a company that ships to Canada.
Dale
Dale
gremlin1234
posted on 9/1/16 at 10:29 PM Reply With Quote
should be easy enough
a search for "a30 wing piping"
found someone who ships worldwide apart from africa!
Austin A30 A35 A40 Wing Piping Beading T Section 2 Meters
ntdwm
edit
though I notice they charge much more than the woolies link from earlier!
Canada EH!
posted on 9/1/16 at 10:39 PM Reply With Quote
Austin Healeys used a gasket like that as the body was aluminum and he outer fender were steel.
Being on this side of the pond you may want to try Moss Motors USA.
Our bug eye sprite has a metal piece between the body and outer fender that is welded in.
Pojo
posted on 10/1/16 at 09:27 AM Reply With Quote
Dale
I am heading to Montreal in a few weeks for a sales meeting, I believe one of my colleagues is from Ontario, if you really want some of this wing piping, you could get it delivered to me, here in the UK and i could bring it across to at least Montreal and possibly Ontario. just let me know if that will help.
Pojo
Dale
posted on 11/1/16 at 10:38 PM Reply With Quote
Thanks for the offer, I will pm you if it comes to that. Thank you again.
Dale
Dale
posted on 12/1/16 at 10:21 AM Reply With Quote
IIRC I used this or very similar on the rear wheel arches of my MK Indy. IIRC Woolies will post to the US for you as well - worth a phone call to see.
http://www.woolies-trim.co.uk/p-1464-wing-piping.aspx
ETA...I made small cuts in the flat section to allow it to curve round the arc of the wheel arch.
[Edited on 12/1/16 by nick205]
