LBMEFM
| posted on 24/4/16 at 12:12 PM |
Cam belt change
Only having been involved in classic car and bike engines I have never had the occasion to change a timing belt. My wife's Citreon C4 belt now
needs replacing, is it a fairly straight forward job, will I need any special tools etc. I will probably buy a Haines manual first.
| posted on 24/4/16 at 12:32 PM |
Should be fairly straight forward although tight. Put a new water pump in while you have it apart.
ianhurley20
| posted on 24/4/16 at 03:53 PM |
If its a 1.6 petrol its a straightforward cam belt change with reasonable access if its a 1.6hdi its not particularly difficult but access is faily
restricted. With hdi don't forget to use lock thread on the crank pulley bolt
