joneh
| posted on 25/5/16 at 12:13 PM |
Second stupid question of the week
'Noon,
I have a 1300 Crossflow engine and a set of twin Webers. What's the minimum/cheapest I'd need to do to the Crossflow to get these working
together?
I figure an uprated cam and some head work. Could I bolt straight on a 1600GT head to the 1300? Will the standard mechanical fuel pump and dizzy be
OK?
Thanks,
Jon
P.S. I know its probably more efficient to use a Zetec but I want to play with the Crossflow for a few years first.
big_wasa
| posted on 25/5/16 at 12:23 PM |
If the chokes are sized to the spec won't they run on a standard engine ?
steve m
| posted on 25/5/16 at 01:03 PM |
If its on a road car, I wouldn't bother with the 1300, even with the 40's
as an old diesel astra would beat you off the lights
The minimum I would put in would be a standard 1600, but any better spec engines, as in cams, porting, etc, the power will go up
also a decent tubular exhaust manifold, is a must
Ive currently got a 1660 xflow, with a 270 cam, lightend/balanced, but have removed the 40's, as I hated the lack of driveability
and fuel economy, so back on the is the old 28/36 dcd carb,
the car is easy to drive, tractable, economical when not on full throttle,
the 40's and manifolds, will be on ebay, when I can be bothered
just my opinion
steve
Adamirish
| posted on 25/5/16 at 02:08 PM |
I can't remember which but either the dizzy or the fuel pump will foul on the dcoe manifold. There is ways round it apparently but what they are
I don't know. Not really much help at all really!
The trouble is though, once you start tuning the engine when do you stop? In all honesty, for what it would cost for a cam, which you will likely need
double valve springs, vernier pulley, duplex Chain etc, playing with stuff to get it to fit, then a set up on a rolling road, you're well on
your way to fitting a black top zetec and having way more power and reliability than you would with a Xflow.
For what it's worth, I have a 1700 Xflow in my car. Over the winter I must have spent £1000 on refreshing the engine and dyno tuning. It made
138bhp which is around standard black top power. You can buy a blacktop zetec for £100.
I do like the little Xflow though!
MK Indy 1700 Xflow
joneh
| posted on 25/5/16 at 03:23 PM |
Thanks for the replies, I'd like to use the crossflow for now. Maybe I'll run it as standard for a bit, I figured using what I have plus
maybe a cam and head would be cheaper than buying a zetec, gearbox etc etc..
Not after huge power, just something easy.
alfas
| posted on 25/5/16 at 05:50 PM |
its not a prblem bolting such carbs (despite you also have a manifold) on a bog standard 1300 engine.
neither you do need to change your dizzy nor the fuel-pump
the dizzy might need a side entry cap, but thats all.
1300 dcoe manifolds have a differnt angle than a 1600 dcoe manifold to give more clearance to the dizzy.
you can also bolt a 1600GT head straight onto a 1300.
[Edited on 25/5/16 by alfas]
joneh
| posted on 25/5/16 at 06:12 PM |
Brilliant, yes i have the 1300 manifold. I'll see what the internals are like on this engine then maybe source a GT head and slightly better
cam.
alfas
| posted on 25/5/16 at 06:16 PM |
this all said: dont expect a power-wonder
| posted on 25/5/16 at 08:23 PM |
People like the 1300 as it can rev higher then 1600. .but obviously thats no repkacement for cubes. Cheaper road tax too.
Fit 1100 pistons to raise CR.
