JONESJ
posted on 16/10/02 at 12:27 PM |
Pinto ALternator in a Lo-Locost Chassis
Does anyone have any experience using a pinto engine in a "lo-locost" IRS Chassis ?
I'm struggling to fit the alternator. It can't live on it's original bracket as the bottom steering U/J is in the way so it has to go higher up.
Fabricating a bracket is ok but if its too high the fan belt fouls the Thermostat Housing and if its too low it fouls the Steering Column. Is there an
easy way round this ? (different alternator maybe ?) I'm using a Sierra Rack and wondered if another one might be better so's I could rotate the U/J
a bit lower down All thoughts and ideas gratefully received. Cheers J.J
James
| posted on 16/10/02 at 03:18 PM |
Contact Merlin (by u2u) as he'll sell you a bracket to mount your alternator higher up. He's using a Pinto and it fits so assuming that the Lolocost
dimensions are the same as The Book then one should work for you.
People have also fitted other alternators- I intend to fit a nice light Japanese one instead of the huge Pinto alternator.
HTH,
James
JONESJ
| posted on 16/10/02 at 03:55 PM |
Thanks James
Making A bracket is no problem mate. It's the fact that there's almost not enough space for the Pinto unit anyway. That's why I thought of maybe
using using another or chnaging the rack position/type
jimmy
| posted on 16/10/02 at 05:17 PM |
Hi ,
Have a look in the photos section as I can remember somebody using a pinto and I think a hitachi (smaller) alternator.
I do not know for sure as the photos section is down at the moment but have a look.
paulbeyer
| posted on 16/10/02 at 08:48 PM |
As another alternative check out an alternator from a Daihatsu Hijet van. It is about the size of a small dogs heart and rated at about 45 amps.
stephen_gusterson
| posted on 16/10/02 at 10:15 PM |
on my ford v6 i moved the alternator to engine top. this also fouled the thermostat housing, so i made a new one. On that engine, the 'stat is
recessed in the block, so the housing could be literally a plate with a pipe welded on to it.
atb
steve
geoff shep
posted on 17/10/02 at 04:46 PM |
Alternator
This may be irrelevant but can you use the original bracket but use a shorter belt to keep the alternator closer to the engine?
JONESJ
| posted on 17/10/02 at 05:00 PM |
Pinto Alternator in a Lo-Locost Chassis
No space mate. the steering U/J sits right alongside the original bracket mounting holes...
Think best solution might be a smaller Alty......JJ
JONESJ
| posted on 21/10/02 at 12:27 PM |
NICEONE: Thanks Paul the Hijet Unit fits like it was made for the job !!! All I have to do now is figure out how to wire it up !!!
paulbeyer
| posted on 23/10/02 at 11:01 PM |
No worries Jonesy,
Does that mean you have bought one? I came across this little nugget of information by accident whilst at a diesel fitters recently. They had a new
one sat on their counter waiting for collection (they wanted £145 for it) I just took the make and model number and crossed referenced it later.
Ian Pearson
posted on 24/10/02 at 06:48 AM |
Is Merlin still around? Tried e-mail & U2U but no luck?
