craigdiver
| posted on 4/1/17 at 08:13 PM |
Radiator anatomy
Can someone who knows cooling systems explain the various connections on this Mercedes 190E radiator that I'm thinking about using for my
car;
On the radiator there are;
2 x 35mm pipe connections top and bottom which I think are coolant in/out.
1 x 21mm pipe connection which at a guess goes to an external expansion tank/filler.
2 x M16 connections, guessing again one for temperature switch for electric cooling fan and one for temperature sensor for temperature gauge.
free picture upload
free picture upload
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
r1_pete
| posted on 4/1/17 at 08:37 PM |
The 2 m16s are probably transmission oil coolers, an oil to engine coolant heat exchanger.
craigdiver
| posted on 4/1/17 at 08:43 PM |
Its item 152365524695 on ebay, if that helps.
| posted on 4/1/17 at 09:16 PM |
As said the 16 mm connections are for an automatic transmission cooler
