Rob James
posted on 13/1/05 at 02:21 PM |
engine positioning
Well I have a part completed book project.
came with pinto mounts with type 9 box mounting in place.
Q?. My gear lever (type 9 box)is about 50mm or so back from the wide section of the tunnel is that correct.
Q?. I am using a 1700 x/f and the mounting looks to be app 200mm or so in front of firewall, does this sound OK? as all the pics in the book show x/f
mounts to be much further forward.
Q?. Anyone got a pair Allegro handbrake cables
Q?, Is a cover plate necessary between x/f and type 9, if so what did you use
sorry its a lot to ask, cheers Rob
Stu16v
| posted on 13/1/05 at 05:57 PM |
Just get the engine/box as far back in the tunnel/engine bay as you can...
Mark Allanson
| posted on 13/1/05 at 08:27 PM |
But make sure that the end of the box does not coincide with the tranny tunnel uprights on B2 - Causes problems with atrying to pass anything else
through the tunnel such as brake/fuel pipes, loom, speedo cable etc (don't ask me how I know..........)
| posted on 13/1/05 at 08:39 PM |
Build your tunnel round your gearbox. You'll get your gearlever where it suits you but make sure you have room for your feet on the pedals.
Mark Allanson
| posted on 13/1/05 at 09:39 PM |
NOW YOU TELL ME
