APR
| posted on 20/2/05 at 09:53 PM |
zetec oil pressure
does any one know the normal oil pressure for zetec ????? as i am running etb gauges and they read 22-90psi and the engine is running at over
90psi..
adz h zetec is the same do we both have a problem
givemethebighammer
| posted on 20/2/05 at 10:25 PM |
my 94 2.0L zetec runs at 4-5 bar (approx 60 - 70 psi).
VDO gauge
Hope this helps
[Edited on 20/2/05 by givemethebighammer]
zetec
| posted on 20/2/05 at 11:15 PM |
60-80 psi once warmed up, never below 40psi on tickover. What oil are you using, I use Ford Formula E, standard spec for zetec., 5w-30w.
[Edited on 20/2/05 by zetec]
APR
| posted on 20/2/05 at 11:22 PM |
standard 5-30 the engine was laid up for 6 months dont know if this has caused a problem. where have you fitted the sender?
zetec
| posted on 21/2/05 at 07:56 AM |
Where the oil switch goes. I wouldn't worry too much as long as you don't have the oil light coming on. in any case if the worst was to
happen you can pick up another engine for less than a full gasket and bearing set.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Stu16v
| posted on 21/2/05 at 08:37 PM |
If the oil pressure guage is electrical, please don't take the readings as gospel. Try with a mechanical guage first...
