paulf
| posted on 24/2/05 at 10:05 AM |
Megajolt configaration.
I am in the process of building a megajolt unit for my car. As I am starting with a blank processor i have built a willette type programmer to flash
the chip and have loaded the s.19 program to the chip.
As i do not have a finished megajolt i have tried to load the configaration software with the programmer also, but cannot get it to connect.
Can anyone tell me if it is possible to do this ? or will the configaration software only run when the processor is in the megajolt? i suspect this is
the case as thinking about it the baud rate must be different.
I have spent hours trying and now think i need to finish the unit first.
Paul
James
| posted on 24/2/05 at 11:02 AM |
Have you tried the Megasquirt forum?
HTH,
James
paulf
| posted on 24/2/05 at 11:21 AM |
I posted on there last night but there not as quick answering as this forum, I was hoping someone on here may know .
I am building the rest of the unit and will try again with the processor installed in that.
The problem is that the configaration is a Java program and i am not sure if i have it set up correctly. I have tried many combinations but no
luck.
Paul.
HTH,
James
GeoffT
| posted on 24/2/05 at 04:46 PM |
Paul,
If you have a look through the Megajolt forum Q&A section (link below) you should find the answers to your questions. I found this
extremely helpful when I had problems setting mine up.
http://picasso.org/mjlj/?q=forum/7
