Author: Subject: crossflow fuel pump
wheelsinsteadofhooves
posted on 4/3/05 at 09:05 AM Reply With Quote
crossflow fuel pump
hi,
whats the standard mechanical fuel pump like for a (slightly tuned) 1300 crossflow? or is it worth it to replace with electrical jobbie near the tank?
cheers,
zane
posted on 4/3/05 at 09:09 AM Reply With Quote
I believe that the general view is that it's fine for mildy tuned engines up to 1600+ with a down-draft carb.
If you're going for higher power, esp. with multiple side-draft carbs then an electric one is probably a good idea.
Also, if the pump ever packs up, then it's worth replacing it with an electric jobbie.
posted on 4/3/05 at 10:23 AM Reply With Quote
Lotus Elan Sprint used the standard xflo fuel pump and it had 126bhp
posted on 4/3/05 at 10:36 AM Reply With Quote
if its goo denough for lotus its good enough for me! will replace at later date if need be but will use for the mo. saves a few quid too.
many cheers for the info,
zane
stevebubs
posted on 4/3/05 at 06:27 PM Reply With Quote
Should be fine.
My 1360 was running on a std mech. pump.
Only switched to Facet when I fitted the Twin 40s.
S
