Author: Subject: Td type 9
Danozeman
posted on 15/3/05 at 10:30 PM Reply With Quote
Td type 9
Lads another questtion from me..
A sierra 1.8 td type 9 box. is the bell housing gear ratios etc the same as the petrol boxes?
Dan
posted on 16/3/05 at 03:34 PM Reply With Quote
Big question --- can't be much worse than the standard type 9.
clbarclay
posted on 16/3/05 at 05:41 PM Reply With Quote
The ratio in the diff is most likely different to petrols (no proof, only speculation), but the gearbox ratios could well be the same.
Most gearboxs (deisel or petrol) have top gear as 1:1, exceptions include early ford 5 speeds whith an overdrive 5th.
posted on 16/3/05 at 06:04 PM Reply With Quote
4th gear is always 1:1 on all 4 or 5 speed boxes -- the only exceptions I know being the 5 speed boxes on early post war British Army vehicles.
Neville Jones
posted on 16/3/05 at 06:19 PM Reply With Quote
I've been led to think that Ford used Pug dieslels for some time. But I could be wrong! Therefore, the bellhousing bolt pattern will be different to the Ford?
Nev.
Danozeman
posted on 16/3/05 at 06:38 PM Reply With Quote
Ford didnt use the pug deisel in the sierras. It is a ford 1.8 older version of the 1.8 endura as in the escorts and mondingo's.
Dan
gazza285
posted on 16/3/05 at 06:41 PM Reply With Quote
Except for all the 2.3D Sierras
posted on 16/3/05 at 06:46 PM Reply With Quote
The 1.8TD was yet an another evolution of the Kent family --- it came a long long way from the 3 bearing pre-xflo 998cc in 105e.
Not a great diesel compared to the 2.3 pug.
gazza285
posted on 16/3/05 at 07:54 PM Reply With Quote
Are you sure that the Endura Diesel was based on the Kent? I know the Endura petrol engine was, but the diesel bears no resemblance that I can see. Ford SA based a diesel on the Kent, but these were never offered in a European Ford that I know of.
stephen_gusterson
posted on 16/3/05 at 07:57 PM Reply With Quote
my impression is that 4th on most cars is 1:1 and 5th comes out something less, like 1:0.88
atb
steve
posted on 16/3/05 at 08:12 PM Reply With Quote
i drive a 2.3d sierra for work all day (you can tell how sucessful we are) however, it is in a car that started with a 1.8td.
i have concluded that the 1.8td box has much shorter gears than a normal type 9 box. The 1.8td has a 3.92 ratio as standard i think (feel free to correct me if you know otherwise). Short diffs should go with a revvy engine, since diesels arent revvy i assumed that the gearbox ratios must be longer to compensate.
My 2.3 diesel has fairly normal ratios i believe, hence the fact that it started with a 3.38 diff to make up for the lack of revs.
david walker
posted on 16/3/05 at 09:19 PM Reply With Quote
When forum users ask for advice or facts, why do people who have no idea what they are talking about try and give definitive answers?
In my (fairly long) experience of using this forum there are only a handful of knowlegable contibutors - Gazza285, Stu16v, the conrodkid and NS Dev being the only ones I can think of!
[Edited on 16/3/05 by david walker]
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
posted on 16/3/05 at 09:43 PM Reply With Quote
do feel free to enlighten us then...
posted on 17/3/05 at 04:21 PM Reply With Quote
Very very distant offspring of the Kent the Kent transfer line was adpated for its producton. I think the only thing left in common with the Kent was the bore spacing.
The endura petrol engine is a Valencia unit not a Kent only looks like a Kent as it was designed based on Kent experience.
[Edited on 17/3/05 by britishtrident]
Danozeman
posted on 17/3/05 at 06:24 PM Reply With Quote
Back to question in hand. Are the type 9's different bell housing and bolt line up on the petrols and diesels?
Dan
NS Dev
posted on 17/3/05 at 07:43 PM Reply With Quote
The bellhousing to gearbox bolt pattern is the same on all the type 9 'boxes, is this what you mean?
gazza285
posted on 17/3/05 at 07:53 PM Reply With Quote
I can't really speak for the 1.8 engines as I have only had limited experience of these in front wheel drive but I do know the 2.3 engines used the long nose box with a different bellhousing for the Peugeot engine, so using one of these boxes with a fourpot bellhousing is out of the window.
[Edited on 17/3/05 by gazza285]
MikeR
posted on 18/3/05 at 12:13 AM Reply With Quote
Ford did change the ratios in the type 9.
The long input shaft (V6 and 2.3td) had a first gear around 3.3.
The short input shaft used in most petrols had a first gear of 3.65.
The p100 had first gear of 3.91, second of 2.29 then matched the short input shaft.
having spent the last 20 mins web surfing i've found one comment that the 2.3 diesel uses stronger first & second gear but they are close together. This sounds a little like the P100 ratios.
MikeR
posted on 18/3/05 at 12:31 AM Reply With Quote
must go to bed..........soon......
anyway, found a german version of the ford technical manual for the type 9. It doesn't list the 1.8td but does list the 2.3.
This claims ford did 3 versions of the type 9/N gearbox and it seem the p100 gearbox was the same as the 2.3 diesel.
The ratios are,
I4 / other/V6
3.65/3.91/3.36
1.97/2.32/1.81
1.37/1.4/1.26
1.00/1.00/1.00
0.82/0.82/0.83
(technically my column headings are wrong as the I4 gearbox was also used in the 2.0 v6 and the 2.3 v6 but i don't think they made it to the uk mated to the type 9 in the sierra)
NS Dev
posted on 18/3/05 at 08:35 AM Reply With Quote
Another thing that I didn't bother putting down before is that the 2.3 diesel 'box uses stronger selector forks than the other 'boxes (don't know if the 1800TD is the same) which is no bad thing. They fit into the "normal" type 9 too.
MikeR
posted on 18/3/05 at 08:41 AM Reply With Quote
Oops didn't mention that the 'other' box when used against a 2.3 diesel was long input shaft.
(no i don't have a life & yes i do spend all day & night reading this forum)
Danozeman
posted on 18/3/05 at 06:34 PM Reply With Quote
Thats what i wanted to know.. Im bidding on one on ebay u see as im too lazy to go to the scrappies.
Dan
