Nitrogeno25
| posted on 17/3/05 at 06:03 PM |
Ford geabox Size
How much wider is a Type 9 comparing to a escort 1600 box.
How much wider is a MT75 comparing to a escort 1600 or a type 9.
Thanks.
NS Dev
| posted on 17/3/05 at 06:21 PM |
The 1600 escort 'box and type 9 are similar in all but detail in terms of external casing width. Where one goes width-wise, so should the
other.
Re the MT 75, I know it is wider but not by how much (I would guess at around 15mm but that's a guess I'm afraid!)
In either case, I don't know your application but it is rarely the maincase of the gearbox that is the problem, more usually the
bellhousing/clutch release arm area, which is quite bulky on the MT75, though again the only one I have is in my road car so others on here are better
placed to supply dimensions!
| posted on 17/3/05 at 06:29 PM |
Attached is a drawing I did a while back of the type 9 with the main dimensions.
Rob Lanes site has more info and picture on some of the various Ford gearboxes.
