Author: Subject: Checking Sierra diff
Northy
posted on 20/3/05 at 03:23 PM Reply With Quote
Hi all,
I've ended up with two LSD's how can I check if they are ok when not fitted to a car (or is this not possible)?
I don't want to clean and paint one to find out its a whines
Graham
turbodisplay
posted on 20/3/05 at 03:41 PM Reply With Quote
You can test the lsd by turning one wheel and see if the other wheel rotates in the same direction.
You can feel if ther is much back lash by seeing if how much you can move the prop before the wheels turn. That is about as much as you can test.
Darren
Liam
posted on 20/3/05 at 04:31 PM Reply With Quote
If one of them's the one you got off me, I can tell you it didn't whine in the sierra
Er, hope that helps.
Liam
Northy
posted on 20/3/05 at 04:33 PM Reply With Quote
That'll do me, it's the cleanest one of the two anyway!
Can you remember what ratio it is?
Graham
Liam
posted on 20/3/05 at 07:08 PM Reply With Quote
Should be a 3.62 as it was on a 2.8 sierra.
Liam
Northy
posted on 20/3/05 at 07:10 PM Reply With Quote
Cheers Liam,
Thats saved me two jobs, working out the ratio, and re-calibrating the speedo!
Graham
