Author: Subject: Sump - front or rear?
Arthur Dent
posted on 22/3/05 at 06:00 PM Reply With Quote
Just a quick question - which is easier to mount? A front or rear sump engine? Thanks.
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
posted on 22/3/05 at 06:17 PM Reply With Quote
what do you mean by front or rear sumped?
Surrey Dave
posted on 22/3/05 at 06:45 PM Reply With Quote
doesn't matter cos in order to make the sump shallow enough for ground clearance ,the sump will be at the front and the back............there's no cross member's so no probs.
Arthur Dent
posted on 22/3/05 at 07:49 PM Reply With Quote
I meant the bump in the oil pan for the pickup.
thanks for the quick responses - go to know its not really an issue.
posted on 22/3/05 at 08:19 PM Reply With Quote
Bolt the pick up in place and then see which way the sump needs to go on?
Marcus
posted on 23/3/05 at 07:11 PM Reply With Quote
I fitted a front bowl sump. This way, the sump pan is close to the front wheel centre line. Makes speed bumps so much easier.
Marcus
Ps. Also eliminates oil surge problems when braking - all the oil moves to the front. Has the opposite effect when accelerating, but I figured I can brake harder than I can accelerate.
[Edited on 23/3/05 by Marcus]
Marcus
Because kits are for girls!!
