Author: Subject: pinto injection
posted on 22/3/05 at 10:33 PM Reply With Quote
pinto injection
anyone know if the pinto injection engines will be a DIRECT swap for a 1.6 carb'd pinto (electrics excluded obviously)? its just ive made a complete exhaust and engine mounts that i dont want to waste...
but 1.6 is a bit crappy, isnt it..
mookaloid
posted on 22/3/05 at 10:38 PM Reply With Quote
I had an idea that the 2.0 has a taller block than the 1.6.
So there might be some adjustments to make.......
Mark Allanson
posted on 22/3/05 at 10:52 PM Reply With Quote
I think you are right, except for the1.6 emax which was a 2.0 with narrow pistons, build for economy
posted on 22/3/05 at 11:12 PM Reply With Quote
taller block, would that make the mounts different too, or just the height? theres no bodywork to worry about yet, plus the exhaust is easy to modify - its just scrap welded together! cheers.
posted on 23/3/05 at 12:46 AM Reply With Quote
1"ish height difference
Shouldn't really matter. Your exhaust should flex that much.
saigonij
posted on 23/3/05 at 07:22 AM Reply With Quote
never had a problem swapping 1.6 for 2lts in capris.
posted on 23/3/05 at 08:11 AM Reply With Quote
buzzin. Now to find one a little closer than Ilfracombe, Devon... £1 on ebay
DrEagle
posted on 23/3/05 at 08:32 PM Reply With Quote
I just swapped a 1600 pinto for a 2 litre one, they are taller. Bonet is now very sung!
Never be afraid to try something new!
Remember that a lone amateur built the Ark with no budget,
where as a large group of professionals spent millions building the Titanic!
