Dick Axtell
posted on 30/4/05 at 03:44 PM |
Facet fuel pump
Will the Facet fuel pump work when mounted vertically? Any reason not to mount it this way?
Dick
TTK77
| posted on 30/4/05 at 05:15 PM |
Facet´s that we have used have worked in every position..
http://www.aar.fi
bigandy
| posted on 30/4/05 at 06:55 PM |
I've mounted a facet solid state fuel pump (competition version) vertically, so it better had work! I can't see any reason why it
shouldn't, providing it is lower than the average fuel level, it should be fine.
If it is significantly above the fuel level, then it might struggle priming itself.
Dammit! Too many decisions....
Dick Axtell
| posted on 1/5/05 at 05:09 PM |
Thanks TTK77.
Chatted to Llama Motorsport at Stoneleigh today. Guy called David Round, very helpful, told me exactly how the interrupter type pump should be
mounted.
(Vertically, with the "nut" end down, so the filter can be accessed).
Llama Motorsport - useful range of hose fittings and also good for brake hoses. See :- www.motorsport-plumbing.co.uk.
