Author: Subject: High oil pressure
Northy
posted on 4/5/05 at 03:06 PM Reply With Quote
High oil pressure
Last year I was woried about low oil pressure, this year high oil pressure!
I took the car out for its first drive this year last night. The highest oil pressure I got last year was around 40psi. Last night I was getting about 60psi at 2500 revs driving along steady and over 80psi when I was thrashing it a bit!
Same oil, filter etc. I just topped it up a bit.
Is this anything to worry about? Is it likely to f**k oil seals?
Car goes well though, forgot how fast it was
Graham
posted on 4/5/05 at 03:09 PM Reply With Quote
I wonder if you have the same problem as I might have (see thread elsewhere) - a sticking oil pressure relief valve. That would explain an unexpectedly high reading, and maybe the cause of your low reading previously.
Shouldn't affect oil seals, as I can't think of any in the high-pressure oil circuit - they're all in the "atmospheric pressure/splashing it around area." I think.
rgds,
[Edited on 4/5/05 by David Jenkins]
posted on 4/5/05 at 03:46 PM Reply With Quote
The bigest danger with high oil presure due to a stuck relief is the can of the oil filter will split take off like a rocket.
Usually if the relief is stuck the oil presure will be normal when the engine warms up, -- if it isn't suspect the gauge, electric oil presure gauges are very prone to dodgey readings
Northy
posted on 4/5/05 at 03:49 PM Reply With Quote
T needle never used to move last year, but its up and down like a yoyo now when I'm thrashing it
Graham
NS Dev
posted on 4/5/05 at 04:36 PM Reply With Quote
My 16v runs similar to the pressures you have mentioned, there are a few threads on the westy forum on this one!
Northy
posted on 4/5/05 at 05:22 PM Reply With Quote
Where? I can't find them
Graham
posted on 4/5/05 at 05:37 PM Reply With Quote
Northy , is your gauge electric? if so it may be worth borrowing a workshop type gauge and checking your oil pressure as already mentioned by B.T. electric gauges are very prone to unreliable readings. It could be that you have an electrics problem causing the readings to fluctuate? H.T.H
NS Dev
posted on 4/5/05 at 06:06 PM Reply With Quote
here: http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?s=82f7d2924d6b376bca2f51e735cf63d9;act=ST;f=3;t=26965;hl=vx+oil+pressure
NS Dev
posted on 4/5/05 at 06:10 PM Reply With Quote
Should put your mind at rest, see my little post on there too!
Northy
posted on 4/5/05 at 07:29 PM Reply With Quote
Cheers.
So its fine then? And it was stuck last year?
Graham
NS Dev
posted on 4/5/05 at 08:54 PM Reply With Quote
Sounds that way doesn't it!??? I am no expert though!
posted on 5/5/05 at 10:29 AM Reply With Quote
I've been thinking about the problems that could be caused by excessively high oil pressure - the only things I can think of are power loss, and possible damage to the oil pump (or its drive) caused by it working too hard.
I'm not sure that the filter itself would burst - although it's a possibility - but there's a fair chance that it's rubber seal could leak or rupture.
rgds,
(who STILL hasn't had a chance to take the oil pump off his own car - I hate new kitchens!)
