Author: Subject: rs2000 ally belhousing
ady8077
posted on 14/5/05 at 06:52 PM Reply With Quote
Hi
Any one used one between a pinto and type 9 box? Do you need the rs2000 clutch lever, or will a sierra one fit?
Adrian
Deckman001
posted on 14/5/05 at 09:09 PM Reply With Quote
As far as i know, they are the same, I have the bellhousing onto a x/flow using the orig sierra type 9 release arm, no probs found
Jason
mookaloid
posted on 15/5/05 at 08:13 AM Reply With Quote
I used the sierra lever but it need a small mod to be able to clear the bolt heads which fasten the bellhousing to the gearbox
Mark
ady8077
posted on 15/5/05 at 08:40 AM Reply With Quote
Thanks guys
The ones on ebay seem to sell cheaper without the clutch arm
Adrian
Dick Axtell
posted on 30/5/05 at 06:23 PM Reply With Quote
Lever Travel
Guys,
Please can you supply the dimension between thw cable stop (on the b/housing), and the end of the clutch lever.
I seem to have approx 25mm mismatch on the cable length. Cable is new from W***f***d, and pedal/box s/h, but from same source.
Am using Capri 1.6 gbox with 1600 xflow, Capri clutch assy installed.
Should I revert to the xflow clutch assy?
