MikeR
| posted on 18/5/05 at 09:33 PM |
Small Engine Mount Rubbers!
Help!
I need some engine mounts that are 15MM thick........ any suggestions? The current ones are 40mm and put the engine 1" too high in the chassis.
clbarclay
| posted on 18/5/05 at 10:36 PM |
Can you not modify/redesign the rest of the engine mounts.
Landrover mounts are slightly thinner @ approx 36mm.
Escort mounts (mk 2 at least) have rubbers about 1" thick, but would need one side bounding to existing engine mount
MikeR
| posted on 18/5/05 at 11:14 PM |
For some reason i've got a real issue with making engine mounts. Don't know why but i'm desparate not to make them!
Silly i know .......... but there we are.
silex
| posted on 19/5/05 at 06:58 AM |
Try these guys
http://www.gmt.gb.com/
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
ned
| posted on 19/5/05 at 08:39 AM |
something i talked about with james the other day..
if you're not keen to remake the engine mounts, another option is to cut out the plate on the chassis (assuming its on top of the 1"
bottom engine bay rails) and re-weld it on the underside, hence making the engine/mount 1" lower..
Ned.
beware, I've got yellow skin
NS Dev
| posted on 19/5/05 at 09:06 AM |
I'll knock some up if you need them Mike
ayoungman
| posted on 19/5/05 at 11:06 AM |
Just looked at the link mentioned ealier in this thread. Bloody useful range of mountings listed. I've just ordered one to adjust the postion of
my engine.
"just like that !"
silex
| posted on 19/5/05 at 11:34 AM |
Glad you liked the link....
Murphy's 2 laws
MikeR
| posted on 19/5/05 at 11:37 AM |
Cheers, could do it myself now i've got two lots of westfield and some luego mounts!!!!!
Just need a bottom in gear moment (or someone to kick it repeatidly!)
NS Dev
| posted on 19/5/05 at 11:38 AM |
Thinking about it, I still have a pile of your engine mounts in my garage, remind me to give those back to you when you come over!
MikeR
| posted on 19/5/05 at 04:19 PM |
great more mounts ......... thats 2 lots of escort, 2 lots of westfield and 1 leugo .....
see why i've got a thing about making my own ?????
