Author: Subject: a-series???
paul_mcq
posted on 26/5/05 at 03:23 PM Reply With Quote
a-series???
just wondering do any of yous no wat mini the a+ series engine came in, i no its the turbo engine but was it n/a in any other car? cheers
JAG
posted on 26/5/05 at 03:26 PM Reply With Quote
oopppss
A+ engine - no idea.
Someone will be along in a minute - I hope
[Edited on 26/5/05 by JAG]
Justin
locogeoff
posted on 26/5/05 at 03:29 PM Reply With Quote
I was under the impression that all metros had A+ in them but I may be wrong, not a mini also but the maestro 1300 had a n/a A+
[Edited on 26/5/05 by locogeoff]
posted on 26/5/05 at 04:09 PM Reply With Quote
A Plus was introduced across the Mini range as the same time as it was put in tha Allegro II.
It was also used in the Masetro/Montego 1300 but although fwd that was not a mini style gears in sump engine it was closer to the RWD A Plus fitted to the very late Marina and Ital.
A plus turbo was ony used in the MG Metro Turbo
Stu16v
posted on 26/5/05 at 10:57 PM Reply With Quote
[pedant]
And the Mini ERA Turbo
[/pedant]
MikeR
posted on 27/5/05 at 12:13 AM Reply With Quote
oooh, i'd forgotten about those ..... had a chance of getting my hands on one a few years ago ....... couldn't afford it, was mint and they wanted something like 10k for it.
hmmmm...........
NS Dev
posted on 27/5/05 at 07:04 AM Reply With Quote
...........they sound more fun than they are though. I'd go for a tuned n/a engine over the turbo in a mini (particularly if keeping the std gearbox!!)
andyps
posted on 30/5/05 at 10:02 PM Reply With Quote
The A+ engine was introduced when the metro came out and was used in all a-series engined metros. At about the same time it was introduced into the mini so most minis after X/Y reg should be A+ engined.
As far as I remember it has a stronger block, and one difference which is visible is that there is no bypass hose between the head and the water pump.
