B@man
posted on 28/5/05 at 12:27 PM |
Bike fuel pump ??
Hi all,
I was wondering if any of you can help on this, Due to a clearence problem I need an electric fuel pump that will work with a weber DGV carb, I
don't want to spend a huge amount of cash on a facet or similar pump and I have been unable to find an electric pump on a carb'd car down
at my local breakers. I found lots of bike fuel pumps on ebay can anyone advise me on this ? I would have thought a pump for a 600cc bike should
easliy be able to feed a 2.0 pinto ??
[Edited on 28/5/05 by B@man]
Projects :
Robin Hood S7 - Deceased !
SSC Stylus 16v - Sold
Spartan Zetec conversion
Rickman 2.0 Petrol (New Engine) - Sold
Rickman 1800 TD (ongoing)
TVR 400SE (Nearly a kit ?)
| posted on 28/5/05 at 12:48 PM |
I saw a BEC down at MK today with an electric one from a Vauxhall Cavalier... noisey but it did the job. Bike one's can be expensive in
comparison
[Edited on 28-5-05 by Hellfire]
Kissy
| posted on 28/5/05 at 12:58 PM |
I can see no reason - something like a Honda VFR750 pump will set you back about £15 on eBay. You just need to verify the flow rate. As a guide a
CBR600 pump flows 650cc/minute, and CBR1000F flows 900cc/minute. Externally most are very similar, and come witha rubber mounting sleeve (I made a
'U' bracket which the pump mount drops on to)
B@man
| posted on 28/5/05 at 05:57 PM |
Cheers I was looking at a CBR600 unit which looks quite small and easy to adapt to 4 wheeled use. I have been busy with google and pumaracing
recommend 0.7L/min per 100bhp so the CBR600 should almost do this, but I think I'll try to find a unit from a 750 just to be on the safe side.
Projects :
Rorty
| posted on 30/5/05 at 05:38 AM |
Subarus use the same Mitsubishi pump as most bikes do except they're slightly larger and flow a tad more. Very neat and compact though and they
come with a rubber mount which slides onto a removeable steel fork. Quite easily adaptable.
Cheers, Rorty.
B@man
| posted on 30/5/05 at 05:14 PM |
I bought a early ZX6 pump off ebay for less than a £10 inc postage. So I will just have to suck it and see !
Er... Rorty..... Nice GIF !!!
[Edited on 30/5/05 by B@man]
Projects :
