blockhead_rich
posted on 15/6/05 at 07:38 PM |
What's this on a 4AGE?
Hi folks
Started to try to piece my engine loom at the mo and I can't fathom out what the F***k these two sensors are or where they should be located on
the engine as they came separately when I bought it. Can't find them in the Haynes manual either. Any pic's would help a lot.
Rich
ADD
| posted on 15/6/05 at 07:41 PM |
sorry rich but cant see your pics, try again!
blockhead_rich
posted on 15/6/05 at 07:49 PM |
Best if I get the attachment right eh!!
[img][/img]
ChrisJLW
| posted on 15/6/05 at 08:19 PM |
They're part of the MAP sensor system. The one on the right is the idle mixture adjustment, if you pop off the rubber cap it'll have a
screw for adjustment. The left hand one is the MAP sensor.
The Vacuum tubing will connect to the intake manifold, I'll have a look see where exactly. The connectors on the loom should be colour coded to
match.
Is the engine from an MR2 or Corolla?
[Edited on 15/6/05 by ChrisJLW]
I've lived a life that's full.
I've traveled each and ev'ry highway.
But more, much more than this,
I did it side-ah-ways.
blockhead_rich
| posted on 15/6/05 at 08:31 PM |
I'm not 100% confident where the engine came from but I believe it was from an MR2 mk1. It's a Red and Black top engine. I've got
the electrical connections sorted but as I say there seem to be numerous vacuum tubes that it could go onto! Next time I'll buy an engine
straight out of a car that I distmantle myself!!!!
ChrisJLW
Vacuum tubing connects to a metal pipe that goes round the side of the intake plenum, this is then connected to a black plastic three
'port' adaptor screwed into the side. Another tube will go from the adaptor to the fuel pressure regulator and the third
'port' is capped off.
The connectors on the loom should come off just after the fuel injector connectors (TPS connector will be at the opposite end)
HTH
Chris
Do you want me to send you a picture of my Intake manifold?
Will get one from t'other side gimme 5 mins
ChrisJLW
| posted on 15/6/05 at 09:02 PM |
Pic from t'other side is in my photo archive.
If you need any other pics gimme a shout.
shades
| posted on 15/6/05 at 10:14 PM |
Rich,
there is a couple of pics in my pic archive of the my mister2 engine bay before I stripped it. Think pic 6 shows the bit you posted attached to the
rear engine bay which a vacume tube connected to the TVIS chamber
shades
| posted on 15/6/05 at 10:21 PM |
Rich/Chris,
I'm at the stage of trying to come up with list of what i need for supplying fuel to my engine.
Can I ask what tank, pump/s, filter, fuel line and connections you have used and where you got them from?
ChrisJLW
| posted on 16/6/05 at 07:42 AM |
quote: Originally posted by shades
Rich/Chris,
I'm still at the engine rebuild stage so haven't even considered it. I assume you're sticking with the EFI system? If so I imagine
a standard MR2/Corolla fuel filter would suffice. These guys do fuel line http://www.bsr-aerotek.com/ . Pump wise could you use the MR2s internal
unit?
shades
| posted on 16/6/05 at 04:42 PM |
Chris,
I've not looked at rebuilding my engine yet or more over give it a good clean paint and service.
I'm just trying to get to a rolling chassi and want to try and get all pipes routed down the tunnel and have the fuel tank pump and filter
fitted before I put the rear diff and hub assemblies in place.
Am planning to fit an external pump. Had a look at the Mr2 one which was in the tank. I already have a tank and it seems simpler to just fit one
externally.
I am stuck with all the fittings and parts I need. There are no suppliers up here in aberdeen (as far as I am aware?) so anything I need I have to
order. Much prefer to see and handle things and choose what I want from a local supplier. But ho hum
blockhead_rich
| posted on 16/6/05 at 07:19 PM |
Cheers for the answers guys - it has solved my problem in double quick time!
As for hints with the instlattion of a 4AGE, I have not quite finished yet but I'm using a cavalier fuel fump (pic in my archive). You'll
need a fuel return pipe too from the engine to tank. Tank will need a swirl pot in the bottom. I've used a combination of metal and rubber
fuel pipes. Just depends upon your own kit as to where to route these. Gear box adaptor & clutch were from Raw. Exhaust will be from Luego
(should get it tomorrow). Low line plenum on order from Raw. Std one is too high.
Wiring and std ECU is my next problem to tackle - any ideas would be greatfully received!!!!
Oh, and Mec 190 rad and I intend to use the Mr2 fan switch.
Let me know if you need any more info.
Rich
