Nitrogeno25
| posted on 28/7/05 at 03:02 AM |
Fiat radiator
I can get an Aluminium Fiat Radiator for cheap that fit really nice in my chassis. The thing is the radiator has a cap to fill it and a small water
outlet for a reservoir in the std application.
What should i do with this outlet, becuase the radiator is lower than the engine so the cap can't be used to fill the system, the same for the
small outlet.
Thanks a lot
Gonzalo
| posted on 28/7/05 at 07:02 AM |
Is it the crossflow Panda type with white/cream coloured tanks --- I have a damaged one lying in my parts shad that I saved to take the fan off.
Certainly size wise it is OK I will have a look at it.
Nitrogeno25
| posted on 28/7/05 at 01:33 PM |
Hi, this radiator cames from a fiat 147 and does not have a tank at one side, only the cap in the top (middle), but I think I should block the small
outlet in the cap and use an expansion tank.
alfasudsprint
| posted on 28/7/05 at 03:18 PM |
I used a new old stock fiat 147 rad due to size. The rad cap is not for filling so ignore it, the small diameter overflow on the neck of the cap tube
goes to my expansion tank....easy!
Nitrogeno25
| posted on 28/7/05 at 05:24 PM |
Thanks a lot!
I plan to use this radiator with a 1.8 zetec, wich engine are you using, is enough for cooling it?
Also the Zetec has an outlet in the thermostat housing that goes to an expansion tank, maybe I should use both, or simply leave the radiator one
blocked.
Thanks again
alfasudsprint
| posted on 29/7/05 at 12:49 AM |
Honest answer is I dont know, sorry. Only ran it a small distance so far, though this weekend intend to take it for a longer one...will let you know.
The size is the biggest you can fit under std nose, only single though but should be enough. I have wired a switch for fan to dash in case. Its a VW
1.8 lump, basically a tuned golf motor putting out 150 horses.
