Project7
| posted on 11/8/05 at 06:18 PM |
Bike TB Ram Pipes/Airfilters
Gentlemen,
Im modifying a set of gsxr 600 Throttle bodies for my zetec install, and I've got to the point where i've got to start thinking about the
setup of the Ram Pipes and Airfilters.
I know the design of the Ram pipes can be critical for maximising power output, and I wondered what other people had done attempting similar
porjects.
Because the spacing of the throttle bodies has been changed from the original design, i reckon it will probably be easier to go for individual
airfilters for each body - can anybody reccomend a manufacturer/supplier.
Cheers for your help,
Tony
stevebubs
| posted on 11/8/05 at 06:47 PM |
I popped into Merlin and picked up a set of 48mm ram pipes for my '750 bodies (See avatar). Came to around 25-30 quid. Attached them using fuel
filler pipe and jubilee clips.
Then just fitted individual socks.
| posted on 11/8/05 at 09:23 PM |
check ebay, i found some trumpets the other day, very cheap seconds
Project7
| posted on 12/8/05 at 05:07 PM |
Steve, the setup in you avatar looks good, have you got a larger version of that picture?
I'll watch ebay for a couple of days, and if nothing turns up, i'll give merlin a call.
cheers for the advice.
stevebubs
| posted on 12/8/05 at 05:43 PM |
yep
stevebubs
| posted on 12/8/05 at 05:44 PM |
(would have uploaded to picture archive but it's not working )
