Author: Subject: Engine identification
Spritely
posted on 15/1/03 at 02:05 PM Reply With Quote
X-flow engines.
How are they identified externally ie how can I tell difference between 1100, 1300 and 1600.
What are their engine numbers references ?
posted on 15/1/03 at 02:16 PM Reply With Quote
There is a code cast into the side that tells you the block type and size. I haven't got it handy, but I'll try and post it tonight.
If you're serious about getting a X-flow, look out for the books by Peter Wallage. There's a whole chapter on identifying engines, etc.
rgds,
RichieW
posted on 15/1/03 at 02:34 PM Reply With Quote
From what I can remember from Classic Ford magazine. There is a code on the block.
If it says AA on it (After the 711 or 701), it is an 1100 or 1300.
1600s have AB stamped on the block.
Apparently all the bores are the same diameter and the differences in cubic capacity are to do with the length of travel of the pistons. I think there are different crankshafts and pistons to achieve this and possibly deeper blocks but I am just guessing now. Someone better informed will be along shortly
jollygreengiant
posted on 15/1/03 at 04:23 PM Reply With Quote
If you cant read the letters the measure the height of the block. Trouble is its so long since I played with one I cant remember what the measurement is.
Me thinks a 1.6 is about 2" from the waterpump to the head face.
Enjoy
fastenuff
posted on 15/1/03 at 07:07 PM Reply With Quote
look at a post several months ago where I asked the same Q LOADS of answers and info
Ingmar
theconrodkid
posted on 15/1/03 at 07:21 PM Reply With Quote
see how many fingers you can get between the stat housing and the waterpump casing,2=11/1300 3=1600
Sideways 2 Victory
posted on 15/1/03 at 10:34 PM Reply With Quote
AA on the block = 1100/1300
BA on the block (Not AB) = 1600
Block on 1600 is exactly 1 inch taller.
Dave
www.nurburgring.org
PeetBee
posted on 3/3/03 at 07:51 PM Reply With Quote
I've searched the site & read the above, but can anyone help me identify the crossflow I've just aquired?
The number cast on the side of the block is: 681F6015DA (definately a D not a B!)
The number stamped at the top of the block is: JP18839
Any ideas?
Many thanks
Fifer
posted on 15/3/03 at 03:50 PM Reply With Quote
According to a chart I have the J in the JP part shows the engine as a 1988.
Browser
posted on 16/3/03 at 07:57 AM Reply With Quote
My only question would be why do you want a crossflow?(ducking and running for cover!)
barrie sharp
posted on 16/3/03 at 08:57 PM Reply With Quote
for anyones info get a free Burton catologe and in the front is very good info about ageing engines
wicket
posted on 16/3/03 at 10:32 PM Reply With Quote
PeetBee
681F was an early X-flow & the Ford chart shows the JP code as April 1969.
PeetBee
posted on 16/3/03 at 10:49 PM Reply With Quote
I thought it was an old one, but it's nice to know for sure.
I want a xflow cos it came with the car, so I know it fits!!
