Author: Subject: Honda Blackbird carbs - one cylinder running too rich
givemethebighammer
posted on 9/9/05 at 08:04 PM Reply With Quote
I checked the plugs on the car tonight and found that number 4 was black from running too rich. I have recently fitted the above carbs to my 2.0L zetec with a Bogg Bros manifold. After speaking to Steve at Bogg Bros, I need to check the fuel pressure and that the needle in the carb that is running rich is seating properly.
Does anyone have a service guide they could email me or have any ideas where best to start. I suspect there may be a piece of dirt stopping the needle seating, but I don't want to take the carb to bits without a manual to help put it back together again !
thanks
big_wasa
posted on 9/9/05 at 08:12 PM Reply With Quote
I got the scanned to cdrom type manual from ebay for a quid...
But other than that I cant help much sos
ps
What fuel pump are you using ?
And can I ask where did you get your exhaust manifold please
givemethebighammer
posted on 9/9/05 at 08:45 PM Reply With Quote
I'm using a the facet pump I had running the webers. There is a filter king regulato rkeeping the pressure down (it's adjusted right down too). I have downloaded a CBR400 service manual the carbs look to be pretty much the same (but obviously smaller), so I do have some pictures etc to go on. I have a blackbird manual as a pdf but it's a 99 on one so only details FI.
I think I am going to check the choke linkage as well could be the issue.
ReMan
posted on 9/9/05 at 09:36 PM Reply With Quote
Likewise I have the early and later Fireblade manuals, your welcome to.
Same but different I guess.
Cable arrived todey
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
givemethebighammer
posted on 11/9/05 at 06:01 PM Reply With Quote
I have been doing some research and have found that he blackbird carbs are normally gravity fed when fitted to the bike. As such they only require 1/2psi of presure to keep them happy. I have a facet blue top capable of 2.5 - 3.0 psi and a malpassi filter king regulator that will regulate from 1psi to 10psi. I think I am going to try turning the pressure right down on the regulator. The question is what effect will this have (if any) on the pump. What I mean is will strangling the pump damage it in any way ? The other option would be to change the pump for one from a ? carb'd CBR600, R1 or other bike, I'm open to suggestions. F3 or F4 CBR600 has been hinted at as being suitable.
Stuart Ainslie
posted on 11/9/05 at 06:24 PM Reply With Quote
I'm using an R1 pump on my BlackBird carbs but haven't run them in anger yet, so can't really advise too much...
