Author: Subject: Back of gearbox open to the world
Humbug
posted on 11/9/05 at 08:57 PM Reply With Quote
I'm nearly at SVA time (just sent off my form) and I am looking over everything closely. Not SVA-related, but I am not sure if there is supposed to be a cover of some sort on the back of the gearbox (Type 9) - at the moment you can see in the back where the lever mechanism goes. I don't think there is any danger of leaking form the box itself, but is it likely to get road dirt in?
If a cover is needed... anyone got one going begging?
Stu16v
posted on 11/9/05 at 09:17 PM Reply With Quote
Are you refering to where a big 'core plug' should be fitted? if so, nah, don't worry about it. The Westfield extension kit relies on this very plug being removed, without anything being put in it's place -reportedly with no ill effects...
HTH Stu.
greggors84
posted on 12/9/05 at 12:40 AM Reply With Quote
As Stu said, you won't really need it as it isnt exposed to much being at the back of the box. I'm using a westfield type extension so have one lying about if you want me to send it over to you if you are worried about it. Just U2U me your details.
Chris
The Magnificent 7!
Humbug
posted on 12/9/05 at 05:44 AM Reply With Quote
Thanks for the replies - sounds like I don't really need it
