Author: Subject: DHLA Carbs
pointy
posted on 26/9/05 at 08:36 PM Reply With Quote
DHLA Carbs
I have twin 40 dellortos.
when starting car (for the first time) using electric pump first carb fills up but 2nd carb petrol is pouring out of both the jets and this is just with ignition on not engine running.
Ideas please.
P.S Engine not started yet
posted on 26/9/05 at 08:42 PM Reply With Quote
Ideas please.
Needle valve is stuck open (or missing altogether!). If stuckt he favorite bodge to just to give the carb a whack with something soft (e.g. piece of wood), but you should idealy take the top of the carb off and clean everything out,
pointy
posted on 26/9/05 at 08:46 PM Reply With Quote
suberb,
i`ll try tommorrow.
andy p
chriscook
posted on 26/9/05 at 09:15 PM Reply With Quote
Mine did this and it was the float height that needed setting.
eagle
posted on 26/9/05 at 10:41 PM Reply With Quote
have you fitted a fuel pressure regulator
pointy
posted on 27/9/05 at 06:57 PM Reply With Quote
you were all right
Float adjusted and no leak.
Still not starting ....but thats for another thread..
andy p
