Author: Subject: help me please
jaythesnake007
posted on 28/9/05 at 10:16 PM Reply With Quote
help me please
help please with new cam 2.1 pinto ht1 cam hell jay here hello first and thanks for reading ,i have had a problem cant get 2.1 going i am a bit stuck got head from burton and cam they gave me a book in the shop with with there bits for sale and a small bit about cam spoke to them on phone had not much help ,i get the tdc on the crankshaft then fit the dial disc put a pointer attatched to a bolt ie a small peice off wire poiting at number 1 tdc on disc then i get confused it rotate the crakshaft to 90 degrees past tdc which i understand then it said rotate the cam so that the number 1 valve is at full lift does it mean that it is full open or full shut ? and it said 106 degrees now i need help please
posted on 28/9/05 at 10:29 PM Reply With Quote
take a breath dude! i nearly passed out trying to read that in one sitting!
Unfortunately, i dont have a clue about cams or valves, and ive drunk too much wine...
Tigger
posted on 28/9/05 at 10:47 PM Reply With Quote
I would say that if number1 is at full lift, then it's fully OPEN.
Tigger
mookaloid
posted on 28/9/05 at 10:49 PM Reply With Quote
you need to rotate the crank to 106 degrees from tdc as in the book
then find the position on the cam where the no 1 inlet valve is fully open with a dial gauge.
Then fit the belt and set your vernier pulley.
you did get a vernier pulley didn't you?
Mark
jaythesnake007
posted on 28/9/05 at 10:53 PM Reply With Quote
yes did get verneir
when you say set verneir. is that at cam timing like say 106 degrees off tdc and no 1 inlet valve at full lift chheers people for help
[Edited on 28/9/05 by jaythesnake007]
